02 600F4i Head light Problem
Old May 13, 2010 | 03:28 PM
honda_man's Avatar
Question 02 600F4i Head light Problem
Im having some trouble with my 02 F4i. I put my fairing back on and now my head lights dont come on and my signal lights are on all the time. On my dash board, the two signal lights are on and so is my high beam light. Also, when my signal light flashes on the left side, my left headlight dimmly lights up. All fuses are fine and wiring seems to be ok. Any suggestions??
Old May 13, 2010 | 08:12 PM
justasquid's Avatar
Sounds as if you have a short, or a bad ground.
Did you kink any of the wires?
I would pull all of the connectors back apart and make sure none of the pins popped out the back of the connectors. Its quite possible when you plugged in the connectors, one of the ground pins came loose and your now not getting a good ground thoughout the system.
Also, why did you have remove your fairings?
Did you change something? Is it possible you wired something incorrectly?
dustinjklee
Oct 19, 2009 12:38 PM
speedemon69
May 30, 2008 05:58 PM
serge1284
Jan 21, 2008 04:22 PM
cbr600f2joe
Oct 24, 2007 05:44 PM
japspec
Nov 4, 2005 06:36 PM
