need help...head light problem
Old Nov 3, 2005 | 10:18 AM
japspec's Avatar
Default need help...head light problem
ok here's my problem on my bike. before one of the head light wiring gets hot but the head light still work. then stop working anymore wich is causing my rectifier regulator to get hot.
does any body know how to re-wire a head light.
Old Nov 3, 2005 | 01:44 PM
abadfish's Avatar
Default RE: need help...head light problem
I don't think your headlight problem is related to your reg/rect problem. There is no direct connection between the two.
Is the headlight bulb a stock one?? I suspect your headlight wiring is getting hot because you're using an aftermarket bulb that puts out more wattage than the stock one.
Old Nov 3, 2005 | 03:59 PM
japspec's Avatar
im using a stock bulb.
Old Nov 4, 2005 | 12:00 PM
japspec's Avatar
can anyody help
Old Nov 4, 2005 | 12:38 PM
japspec's Avatar
does the head light wiring has a relay?
Old Nov 4, 2005 | 12:54 PM
chainstretcher's Avatar
Admin Emeritus & MVN
I don't know model specific details for your F2 -- you'll really need a manual. But as long as the battery has juice and the fuse isn't blown the headlight should light up. The rectifier is gonna get warm just because of where it sits -- but it shouldn't be "red" hot.
Old Nov 4, 2005 | 06:36 PM
MofoSachem's Avatar
best bet is to get the service manual. you can download from many locations.
honda_man
May 13, 2010 08:12 PM
dustinjklee
Oct 19, 2009 12:38 PM
speedemon69
May 30, 2008 05:58 PM
serge1284
Jan 21, 2008 04:22 PM
cbr600f2joe
Oct 24, 2007 05:44 PM
