01 CBR 929rr jerks on quick acceleration
Old Aug 12, 2016 | 02:13 PM
Mccbr929's Avatar
Default 01 CBR 929rr jerks on quick acceleration
Title says it. Just started two days ago randomly. Put some sea foam in the gas tank and changed the oil today and it's still doing it. If I accelerate in 1st slowly it's fine but if I get on it it jerks 3 times. Only in first gear. Sometimes it'll do it once is 2nd but no other gear. Any ideas?
Old Aug 12, 2016 | 03:13 PM
74demon's Avatar
misfire maybe?
Old Aug 12, 2016 | 03:37 PM
Mccbr929's Avatar
Originally Posted by 74demon
misfire maybe?
I'm a newbie. How do I fix misfires? Lol
Old Aug 12, 2016 | 04:41 PM
74demon's Avatar
First, you would need to diagnose it as a misfire. Then figure out the cause of the misfire. Finally remedy the cause of the misfire.
Coils?
Plugs?
Valves?
Injector?
Compression?
wiring?
ECU?
Vacuum issue?
Could be a lot of things.
Old Aug 14, 2016 | 09:08 PM
Conrice's Avatar
If you could post a vid of it running with sound, we could tell if it's misfiring... But there's a ton of things it could be with the limited information we have...
Old Aug 15, 2016 | 08:30 PM
Jaybird180's Avatar
Coils?
Plugs?
Valves?
Injector?
Compression?
wiring?
ECU?
Vacuum issue?
I'd agree with this as an initial diagnosis. But I'd confine my search to electrical, which removes compression and vacuum issues as culprits. If it doesn't turn up, then I'd look at those. How's your chain and sprockets?
UnderAssumedName
May 2, 2011 05:21 AM
iamwitit02
Oct 11, 2010 06:10 PM
StreetPower
Jun 21, 2008 04:08 AM
flashpoint
Jan 2, 2007 12:34 PM
LouSiffer
Sep 19, 2006 05:21 PM
