Words that cause problems...
So i know Woo has been making comments about it but i want to start a list of words that cause the site to break and not allow you to post ... when some people can't post, it's because you are using words that are reserved and for some reason, the software is crashing on it ... here are the words i have found that blow things up ...
Omit the periods:
U.S.E
W.H.I.L.E
L.I.K.E
H.A.V.I.N.G
W.H.E.R.E (sometimes)
C.O.M.P.A.R.E (sometimes)
Now some of these words work SOMETIMES ... but if you are not able to post see if these words are there and change them ... might help out...feel free to add to the list
Edited by KB to Notify you that clicking on PREVIEW before you post will let you see if your post will go through or not. If it shows errors in preview, click GO BACK TO POST (from preview mode, not your browser) and find the offending word. That way you do not lose any info. and don't have to retype anything. If it shows the post in preview mode without any errors, your set, just click SUBMIT POST and it should go through (you may want to sel.ect all and copy before you post if you want to be on the safe side).
I will try and keep list updated as members find other words but THE ABOVE WORDS SEEM TO BE THE MAIN CULPRITS.
Here are other words some members say (sometimes) causes them problems:
S e l e c t
I n s e r t I n t o
J o i n
D e l e t e
U n i o n
D r o p
Omit the periods:
U.S.E
W.H.I.L.E
L.I.K.E
H.A.V.I.N.G
S e l e c t
I n s e r t I n t o
J o i n
D e l e t e
U n i o n
D r o p
