wtf am I that dumb? spark plugs
Old 05-18-2011, 01:04 PM
Honda125 358's Avatar
Default wtf am I that dumb? spark plugs
I'm putting new plugs in the bike and it's giving me a hard time. First off the airbox has a sensor on the left side and I didn't know what to do about that so I just unscrewed it (which was a bitch, and the little hose was stretched more than I would have liked. I'm sure there's a better way to do this).
but now I have everything out of the way. Look at my attachment (the pair valve mod, but I'm just using it as reference). The 4 black caps on top of the head that are plugged into the white harnesses are on the spark plugs, yes? HOW DO I GET THOSE DAMN THINGS OFF?!
Old 05-18-2011, 01:12 PM
Dodgehemi7's Avatar
Turn and pull up on them. You have to unplug the wire from each one. Then just twist and pull up. They might be stuck so turning them should help loosen it up. Hope that helps.
Old 05-18-2011, 01:57 PM
ButkoF4i's Avatar
Pull that mother!
Old 05-18-2011, 02:00 PM
Okay, I'm sure these are the original plugs so they are probably stuck well. I just wanted to check before I started yanking on things and breaking it....
Thanks guys!
Old 05-18-2011, 02:51 PM
nowensby's Avatar
Hehe... Sometimes they're stuck on there pretty good. Just keep pulling!
Old 05-18-2011, 04:19 PM
Kuroshio's Avatar
Be glad it's FI and not carbs. Pulling the carbs for the first time since being manufactured usually requires C-4
Old 05-18-2011, 05:08 PM
oxyg3ne's Avatar
you need good patient to do this haha... i did mine and you need to have some little girl's hand haha
Old 05-18-2011, 05:11 PM
crazychris1981's Avatar
yep those are the coils.. On a car i have torn the boot by not turning it first so give them a good twist and you might have to use long needle noise plyers or spark plug boot puller..
Old 05-18-2011, 06:21 PM
AlexF4i227's Avatar
turn em and with a small flat head push them lightly
baseballkid
10-04-2012 07:48 AM
SAXON
03-19-2009 04:01 PM
some guy #2
07-31-2007 12:18 AM
The Twisted Grip
05-31-2006 01:48 AM
Quick Reply: wtf am I that dumb? spark plugs
