Won't prime and/or start
Old Jan 27, 2011 | 12:45 AM
themacdaddy1245's Avatar
Default Won't prime and/or start
Hey i have a 01 f4i, after a ride the other day when i was going to return home, i turned the key and noticed the fuel pump didn't prime, and the engine would try to turn over and would start, but once i released the starter button the engine would die.....
Now the bike never doesn't start, all the dash lights work, but i noticed the headlights, and the front turn signals don't work and doesn't prime......any ideas?
Old Jan 27, 2011 | 03:16 AM
GDM YO's Avatar
Something with the ignition switch / kill switch, as the headlights run through that possibly?
Old Jan 27, 2011 | 08:47 AM
R Dub's Avatar
October 2011 ROTM
Check the front gray harness that run down by the left intake and plugs into the main wiring harness. Make sure all the wires are solid in the harness with no corrosion especially the green ground wire. Also make sure the harness is fully plugged together. Put a little dielectric grease on it before you put it back together. Try it out and let us know if this fixes your problem or not.
Old Jan 27, 2011 | 06:35 PM
I cleaned off all the connections and put dielectric grease on them...still no luck....all the wires and connections looked fine....this is stressing me out
Old Jan 27, 2011 | 09:52 PM
R Dub's Avatar
October 2011 ROTM
Check the kill switch connection and the BAS as those will stop the pump from priming.
Old Jan 28, 2011 | 06:46 PM
One thing i noticed today was that when i have the kill switch off, but push the starter, the front turn signals will come on (both of them)...if the signal is on it will blink, if not it will just stay lit....the headlights still stay off...and the high beam indicator turns off anytime you push the starter whether the engine start button is on or not....
Old Feb 2, 2011 | 04:28 AM
help
Old Feb 2, 2011 | 02:41 PM
DarkNinja75's Avatar
Your headlight operation sounds normal. My shot in the dark is that your fuel pump is bad. Either that, or the connection is. I'd trace the wires to/from the fuel pump to make sure they're good. If so, try replacing it.
Old Feb 2, 2011 | 05:49 PM
bowflexmaverick's Avatar
I almost guarantee it is something wrong with your kill switch. Mine was having the same problem, took apart the kill switch and found a wire disconnected inside. Re soldered it and everything worked again.
Old Feb 3, 2011 | 11:37 AM
Irishboxer08's Avatar
Always start with simple solutions. Check fuses first. Spray starting fluid down your intake and try turning the bike over. If it starts and runs for a second then you know you have spark, so then turn your attention to fuel. If you spray starting fluid down your intake and it does nothing I would turn to an electrical problem. I don't know if you have any friends with F4i's but what I have done in the past was just really quickly swap out fuel pumps so I could eliminate that as a problem. Besides, fuel pumps are pretty cheap... after that I always had a spare one laying around just so I could at least check things and not go crazy back tracking. The more problems you can eliminate the better.
