Won't Crank, Blank Red Light On
Old Dec 22, 2011 | 11:09 AM
colbyDANIERI's Avatar
Default Won't Crank, Blank Red Light On
Got back from college and all I want to do is ride my bike. I went to start it and the battery was dead. I hooked it up to a truck and it charged the battery. The lights turn on and if i remove the clips from the truck battery and touch them, they spark. However, when I try to start my bike, all it does is dim the lights. It won't even begin to crank the least bit.
There is a blank red light that is on on the dash. I don't know what that light means.
Please Help,
Colby
Old Dec 22, 2011 | 12:10 PM
74demon's Avatar
whats the battery voltage standing and while trying to crank? sounds like the battery is dead. BTW, don't jump it off a running car.
Old Dec 22, 2011 | 03:44 PM
The truck was off, is that ok? I have a voltmeter hooked up on my bike and it has all the green lights lit, and they stay lit as I try to start it, but it doesn't even start to crank. I heard something about a sensor that can have a problem and cause this.
Old Dec 22, 2011 | 03:59 PM
74demon's Avatar
there are many sensors and switches that can cause this. if the battery is good, the next test is to see if the starter is getting signal from the relay and switch. if not, test the kill switch, start switch, and neutral switch.
jumping from a nonrunning car is ok.
the bike is in neutral, right?
Old Feb 8, 2012 | 09:26 PM
stewyF4i's Avatar
Check your kick stand switch!
Old Feb 13, 2012 | 11:44 PM
Acespad3's Avatar
i was just gonna say.. if you have a red light.. you need the green neutral light on too. put it in neutral
Old Feb 14, 2012 | 10:59 AM
chambers's Avatar
Are all the normal lights coming on when you try to start it, if I remember right there is a blank red one, green neutral, and your FI light? Are you trying to start it w/ it the battery hooked up to the truck battery? Check your fuses to make sure you didn't blow any as well.
Old Feb 17, 2012 | 08:21 PM
epills_7's Avatar
so what exactly does the blank red light mean?
adapt63
Mar 21, 2014 04:20 AM
donnygeewebb
Jun 30, 2012 11:17 AM
cbrballer
Aug 29, 2009 08:57 AM
Mac Daddy
Feb 26, 2008 08:45 AM
Triangle
Jul 19, 2006 04:54 AM
