Wiring front turn signals
First off, I have hotbodies two wire flush mount front signals. The previous owner cut off the plug of both the wiring harness and the stock signals. So im left with a few wire that I have no idea where they go. All I want is to wire the turn signals, I understand how to wire the 3 wire to 2 wire stuff, but these don't have the plugs so it's a little different. I can get a picture if needed, but I just need help knowing which wire goes where.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
I will get them as soon as I get home. But to try and explain it as best as possible, there is like 3 green wires and 1 blue wire. The green ones are eventually all joined together as you go down the wiring harness. I know these are the wires as I touch the red to the blue, and the black to the green wire. It maybe vise versa, I can't remember off the top of my head, ill get a pic asap.
I got it, the previouse owner hacked every wire off including the headlights for the street fighter stuff. There was like 4 green wires total, but I figured out that they are all ground wires. So I just did one wire from each headlight and then one wire from each turn signal and wired those to the green wires.
All is good! Thanks for the help!
Lowridese
05-01-2010 01:12 AM
ciupe
03-17-2006 10:53 AM
