Will I Have Enough Back Pressure
Old Jul 24, 2009 | 01:25 PM
__Z__'s Avatar
April 2011 Ride of the Month
Default Will I Have Enough Back Pressure
If i run my 2" inch tube into two tubes with two 1" inch tubes.... the tube will go into the muffler which will have a 1" aluminum or stainless steel tube with a ton of little holes in it, surrounded by stainless steel wool with fiberglass packing around it.... all of it will be inside a 2"x2" aluminum square tube.... and then out the outlet...... will i have enough back pressure..... thats 1/2" of stainless steel wool and fiberglass combined..... or do i need to go with a bigger aluminum tube?
Old Jul 24, 2009 | 02:41 PM
bakesf4i's Avatar
trial and error, go for it!
Old Jul 24, 2009 | 02:44 PM
__Z__'s Avatar
ya i just prefer to get it right the first time though haha.. i dont want to have to tear it apart and buy all new raw material and do it all over again....
Old Jul 24, 2009 | 03:48 PM
2H company's Avatar
tube tube tube tube tube tube... wow lots of tubes are involved in this lol j\k
Maybe you just use your old system's dimensions? Or this one is going to be completely different? Don't see the reason why it would though.
Old Jul 24, 2009 | 04:28 PM
jp_greenville13's Avatar
Fallopian tube
Old Jul 25, 2009 | 03:37 AM
drunkinmist's Avatar
Sprocket Hauler and Savior
just to many tubes to deal with, without some kind of drawing. sounds something like my buddies tl1000
Old Jul 25, 2009 | 05:40 AM
Pictures ye want pictures ye shall recieve.
Old Jul 25, 2009 | 08:03 AM
__Z__'s Avatar
please stop posting bs in my threads......
thanks
Old Jul 25, 2009 | 08:28 AM
__Z__'s Avatar
here is a quick picture i made up..... basically my two inch mid pipe y's off into two 1" goes into the canister made of a 2" aluminum square tubing..... alot of holes will be put in the 1" tubing throughout the canister.... then the tube would exit the canister and be slash cut (i didnt draw that part it) the portion of tube with the holes in it would be wrapped in 1/2" of stainless steel wool and then fiberglass exhaust packing... im curious if that would create enough back pressure.... or do i need to go with bigger square aluminum tubing.... say 3 or 4".... also i mentioned something to my buddy and he said i may not need to reduce down to two one inch because of the venturi effect... i could possibly run two 2" tubes instead of 1"? anyone have opinions on that...... here is the pic
Old Jul 25, 2009 | 05:16 PM
Dude relax and have a sense of humor. I'm following this thread becasue I want to know where it's going. I'm also keeping at at the top.
Anyhow sounds like it could work. I havent taken classes on fuels yet so I don't know much about airflow patterns and pressures. What does everyone else think?
hughtexjassole
Jan 7, 2012 07:59 PM
itsme71190
Jan 12, 2011 10:04 AM
stupidlogic
Oct 2, 2008 06:19 AM
Lotsokids
Feb 26, 2008 05:47 PM
zach4i
Sep 26, 2007 09:24 PM
