Where do these go?
I'm putting my f4i back together and I need to know where the idle adjustment line, the fuel tank breather, fuel tank overflow, and coolant overflow are routed. Does anyone have pics/a good explanation for me? Thanks in advance
I'll look through my Haynes manual and see if I can help you, but you should really label everything as you take them off or put numbers on the hose and the part it has come off to make reassembly a simple affair! I'll go check my manual!
Hi. I had a look through my Haynes manual but it wasn't very helpful and there are quite a few pages to read regarding the fuel injection and the various connections of the hoses. Sorry I wasn't able to help. See if you can borrow the Haynes from a friend or maybe buy one off ebay or amazon. You can sometimes pick up a good used one for a few pounds.
Thanks for the advice man but I purchased this hoodrat bike from a less then perfect previous owner who didn't have it assembled correctly in the first place. He even crimped and ruined the banjo fitting fuel line by mounting it backwards. I downloaded a manual I'm going to look through
