When front brake is applied... Left turn signal comes on???
Old 06-29-2008, 03:43 AM
yrallofthenamestaken's Avatar
Default When front brake is applied... Left turn signal comes on???
Pretty much as the title says it.... After I finished installing my hids and whatnot I took the bike for a spin to see how they look and so on.
I noticed my left turn signal blinker on the cluster was coming on everytime I pulled the front brake lever.... It's only the front brake (nothing happens if I apply the rear brake)... I didn't mess with any wiring at all besides the ballasts and to the headlight. The actual side marker and rear turn signal marker comes on and imeditately turns off when I release the brake lever so far.
So I'm lost since I'm clueless with bikes still
Anyone have any idea why this would happen?
Old 06-29-2008, 04:18 AM
RojerLockless's Avatar
Default RE: When front brake is applied... Left turn signal comes on???
That's pretty funny... nice ws.6 I have one too
Old 06-29-2008, 04:18 PM
Jaybird180's Avatar
Threre's a switch in your front brake that activates the brake light. Perhaps you crossed wires when you were wiring up your HIDs. That's the ONLY electical part on the front brake. Its not like you have power assist or anything.
Old 06-29-2008, 04:46 PM
jimd2p's Avatar
+1 to Jaybird. Something has to be plugged in wrong after you reinstalled everything.
Old 06-29-2008, 11:26 PM
I didn't unplug anything besides the main connector piece in the upper fairing. I only messed with the ballasts as far as wiring goes.
I'm absolutely stumped...
Plan on messing with it a little tomorrow morning and see if I can find anything wrong at all. Can't think of anything that could be wrong though....
Old 06-30-2008, 01:03 PM
Jaybird180's Avatar
Well somehow the brake electrons are partying with the lighting electrons. Go in there and tell them to brake that sh*t up (LOL)
Old 06-30-2008, 02:38 PM
yeah i have no idea how that happened your brake line is a cable with nothing to do with electronics.. but it's funny thinking about breaking turn signaling
Old 07-01-2008, 04:32 PM
ampfp's Avatar
check ground wire in front headlight assy.
Old 07-02-2008, 03:13 PM
Daemian's Avatar
cant believe no one knew this, it is obvious that his blinker fluid has run low... fill 'er up and she'll purrr like a kitten. but make sure you get the really expensive Honda stuff.
RaiderAlumn
04-15-2011 06:05 PM
Quick Reply: When front brake is applied... Left turn signal comes on???
