What Octane are you running
Old Apr 1, 2008 | 10:09 PM
  #21
slolane's Avatar
Default RE: What Octane are you running
87 octane, no problems thus far.
Old Apr 1, 2008 | 10:41 PM
  #22
RatherHaveAnR6's Avatar
ORIGINAL: Kevin48
Just out of currosity, What fuel are you running in your bike. I have an 01 F4i and have been using 93 octane which seems to be running good. I dont have the owners manual so if someone with an 01 could tell me if im not supposed to be running 93 please post it
ITS MADE TO RUN ON REGULAR! [sm=WTFsgign.gif]... why is this a 2 page thread?
When did the thread change to "What will my bike do on race gas?", or "Tell me where you get your gas" [sm=pcwhack.gif]
Its not going to hurt the engine if you run a higher octane... it wont make you loose power... it actually makes you run a cooler temperature. Its cleaner...Unless your running a higher compression, or an advanced timing, you don't need higher than regular!
All the guy was asking, as seen above,was what gas is the bike supposed to run on becausehe didnt have the manual when he got his bike.
Old Apr 1, 2008 | 11:13 PM
  #23
devlzluv's Avatar
lol ya i agree with u ghost & rather, k ya i get my gas from a sunoco in my are that sells 100/110/120 gas so when i go to dick around on my crappy backroads i get that. but u guys are right it got to a race gas thread, if its not tuned and just stock u can run either or gas it doesnt matter. since i upgraded the exhasut and pcIII and filter if i put in 87 it runs sluggish and like pooo but when i was running stock i ran 87-93 and not much of a diff.
so to answer the question for the main thread run whatever you want it wont affect it at all, lol but if u get a chance throw some race fuel when ya can even stock youll notice a diff with it and plus the smell makes you fell all good and ****
Old Apr 1, 2008 | 11:23 PM
  #24
slip_'s Avatar
Yeah, I normally just run 87 in mine. But my Dad had 110 from the local Sunoco, and wanted to put it in my bike for ****s and giggles. The smell after it burns is definately addicting lmao. And it leaves a white residue on the exhaust tip instead of that black. I didn't really notice that much of a difference if there was one though.
Old Apr 2, 2008 | 02:01 AM
  #25
ohriley's Avatar
it says 86 or higher for the 02. i run 89, andit runs great. just as long as it doesn't knock your good!
Old Apr 2, 2008 | 01:36 PM
  #26
65ShelbyClone's Avatar
ORIGINAL: Kevin48
Everyone is talking about this possibility of a knock with the 87. If its not bad to run the 93, and you get no knock, then why not do it. Think about it, were only talking about a few gallons here. At my gas station, the 93 is about .20 cents more a gallonthan the 87, so to fill it up what are we talking about....one dollar? As long as the 93 is ok to run, ill stick with that and pay the extra dollar, besides i dont have to worry about, or listen for any knocks.
I don't understand that rationale at all. If you don't need premium fuel, pay more for it anyway and leave a little power on the table just because you can? [sm=wtf.gif]
For those saying that premium is cleaner, cooler burning, hotter burning, slower burning, resistant to burning, or whatever.........it is none of those things. Here are some excerpts from posts of mine in a few threads just like this one:
ORIGINAL: 65ShelbyClone
Also, octane does not refer to the rate of burn or flame speed of a fuel. It describes a fuel's resistance to autoignition. Methanol is ~115 motor octane, but it has a flame speed that is faster than gasoline. High octane is great if you need it, but it will cost power if you don't.
That autoignition can come from heating due to compression, residual heat in carbon deposits, radicals in exhaust byproducts left over from the last cycle, and even too much ignition advance. However, spark knock doesn't quite work the same way as flat out autoignition.
High octane fuel will not burn "hotter." Did you know that methanol has a motor octane of about 115, yet little more than half the BTU content of gasoline? Compressed natural gas has an octane rating of about 130, but 1/4 the energy content by weight of gasoline. Pump gas has a negligible difference of energy content between the grades.
The bottom line is that the F4i's ability to run on 87 R+M/2 octane fuel shows how conservative Honda and/or Keihin was with the ignition advance curve. This is especially significant considering there is no knock sensor. Another aspect of being able to run 87 fuel through a 12:1 engine is the relatively high rpm. There is simply less time for the necessary chemical and thermodynamic reactions to take place in the cylinder. An efficient chamber design also helps. I suspect that if Honda had taken full advantage of their design, none of us would be able to run anything less than 94-96 fuel.
Now that we have yet another beaten-to-death octane thread, all we need now is another "what oil is best" thread to complement it.
Old Apr 2, 2008 | 03:14 PM
  #27
FLYOU's Avatar
87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87 87
Old Apr 2, 2008 | 04:01 PM
  #28
slip_'s Avatar
As tiresome as these threads are, I think it's very healthy for the community to be exposed to the actual factual information that ends up getting repeated on the last pages. It's what keeps this community alive lol.
Old Apr 2, 2008 | 04:28 PM
  #29
sluijs01's Avatar
my bike runs on sunshine and happiness
Old Apr 2, 2008 | 04:34 PM
  #30
Tahoe SC's Avatar
ORIGINAL: sluijs01
wow...just wow...is it pink too?
