What Gas do you run?
#31
-it's not going to make it worse
-it will probably in the very long run help with engine quality
-there is probably no performance boost
-so if you feel like using it, use it.
Easiest way is to try the different levels of gas and determine for yourself. With my cars, I noticed a big difference in my Celica, not so much in my Jetta.
#33
The way a high octane can reduce performance in a vehicle is as follows...
Oil when refined or "cracked" seperates much like oil and vinger in a jar.
With oil it seperates out by the number of carbon atoms in the chain of compounds. (i.e. octane=8) The lower the carbon count the more volatile the fuel.(diesel has far more carbon atoms, propane has far less)
So the refiners mix the subtance octane with heptane to use the otherwise useless heptane. This is where the ratin partly comes from.(additives to reduce not has since added their influence to octane rating) The high the ratig the more resistant to ignition the fuel is.
So in simple terms it takes more spark/heat to ignite 93 octane vs 87.
So in a carbed bike with no ecu the bike may not ignite all the fuel causing back fires and dieseling after shut off.
That is fuel science in a nut shell
#34
#35
I can't believe this is an argument. The engineers, ENGINEERS, say 86 or higher. If you have a degree equivalent to theirs or you manufacture your own motorcycles, I'd go with what those guys tell you.
You wont get better mpg's, you won't get more performance (unless you have some mods and a tune for them), you WILL have less $$ in your wallet.
Go with 87 oct, you'll be ok. Hasn't failed me yet.
#36
#37
Ethanol simply put is great if you are in the business of growing sugercane.(you make lots of money)
In blends it does nothing more than reduce fuel economy.
This goes back to the previous post of reduced performance.
Ethanol has a much higher octane rating. For maximum efficency the compression in the engine would need to be much higher. (Like a diesel or alcohol burner race car)
Basicly ethanol blend is all politic with greater cost for the public with little to no enviromental benefit.
With out the proper engine tuning ie compression even the E85 vechiles require 50% more ethanol fuel than it would need if it were pure ethanol.
I prefer no ethanol because I see it as buying a soda at McD's and having the cup packed with ice.
#38
