What to check after a crash?
Old Sep 7, 2010 | 06:18 PM
Krux's Avatar
Default What to check after a crash?
What would you check after a crash
So far all the seals are good. Runs good and has power(rode it)
I re-aligned the rear tire to make sure everything was good and got a new brake set up for the rear. Found out from the previous owner took the return spring out so the rear brake lever wouldn't come up. Hmm I wonder if this is what caused me to crash.
Other than that I checked the frame and it all looks good. Maybe its me but the motor sounds like it has a little more buzzing noise in it but it could of always been there.
Anything else?
Old Sep 7, 2010 | 06:54 PM
teko1020's Avatar
Your vitals.
Old Sep 7, 2010 | 07:37 PM
Zero1080's Avatar
You should check the motor mounts, well, where it mounts to the frame anyways. If it's a high speed/impact crash, things can jar loose.
Check your bank angle sensor too! I know mine no longer works however it is still in tact. Cause if you wreck again, and the bike never shuts off, that engine is toast.
Old Sep 7, 2010 | 08:21 PM
Krux's Avatar
Vitals are good :check:
Motor mounts are good and tight still:check:
Bank angle sensor ill have to check that. Again I guess if this bike goes down I hope it burns I'll be done after that haha
Old Sep 7, 2010 | 08:25 PM
jp_greenville13's Avatar
You drawers!
Old Sep 7, 2010 | 08:26 PM
Sorry Couldn't resist
Spdyg_AK
Apr 18, 2012 11:02 AM
G_954rr
Dec 17, 2011 10:57 PM
philthethrillohio
Apr 29, 2009 03:51 PM
gamble
Nov 27, 2005 09:00 PM
