Weird Problem with Clutch
Old Aug 23, 2008 | 11:35 AM
Jettfiery's Avatar
Default Weird Problem with Clutch
Ok I don't know what caused this to start but i can't seem to figure it out. I tried searching but came up empty handed. So it almost seems like my clutch is always engaged even when i pull the clutch lever in. I checked the cable and tried adjusting it but it just doesn't seem to work. i'm probably adjusting it incorrectly...
anyone else ever have this prob?
Old Aug 23, 2008 | 11:36 AM
RojerLockless's Avatar
Default RE: Weird Problem with Clutch
most likely you burnt out the clutch this happened to my zx-7 Kawasaki a long time ago.. did you do any burnouts lately? its not that cheap to fix it if you fried the plates. but thats what it sounds like to me
Old Aug 23, 2008 | 11:52 AM
Jettfiery's Avatar
no no burnouts. it just kinda happened. i usually granny ride the thing since i've owned it.
Old Aug 23, 2008 | 03:10 PM
usetheffours's Avatar
when adjusting the tension you should have 1/4" of "play" in the lever. check you oil also, not enough or old oil will affect your clutch.
Old Aug 23, 2008 | 07:40 PM
Stephens's Avatar
You dont have to do burnouts to burn up your clutch. You can do wheelies and burn it up too. They are pretty simple to change out.what you need are new friction plates. you can find a clutch on ebay or www.bikebandits.com you can find the friction plates there too.
Old Aug 23, 2008 | 08:23 PM
krash's Avatar
burnt plates will cause them to stay engaged? I would think just the opposite, that the clutch would slip even when engaged. but, I have never had to deal with the clutch, so I could be completely wrong.
my first guess would be that the cable is not adjusted correctly
Old Aug 25, 2008 | 07:40 AM
Jettfiery's Avatar
yeah i've adjusted the cable several times. It seems to have the correct freeplay in the lever tho, so i don't think a new cable will help much, but do u think i should try that? I'll also try new oil as well before ripping into the clutch...
Old Aug 25, 2008 | 12:22 PM
Stephens's Avatar
When you pull the lever in, that will dissengage your clutch. When it is release the clutch is enabled. So when you pull it in you can't shift? Or come to a stop without putting it neutral, the bike won't idle when you pull the lever in?
Old Aug 25, 2008 | 02:35 PM
CBR_SLIM_T's Avatar
Did you check both clutch adjustments, or just the one on the handle bar? Does the clutch lever have tension when you pull it in? If so, then yeah you probably need new friction plates.
Old Aug 25, 2008 | 07:43 PM
Jettfiery's Avatar
Stephens, that's the strange part. I've been riding motorcycles for a while and haven't encountered such a prob; i've encountered slipping just not the opposite lol. So in neutral it's fine, once in first gear it just wants to move forward. if i have the brake on, it'll stall. otherwise it'll be in first gear and rolling. and i can shift up and down fine, BUT it feels like it BARELY disengages, but it seems to be getting worse and worse.
And yes, CBR_Slim_T, i adjusted both. after realizing the lever one was at it's limit with no effect, i turned to the one by the engine for major adjustments. I have plenty of tension in the cable. So that is why i'm going to say it's not the cable.
