warped front rotors, cheap upgrade alternatives?
Old 10-18-2007, 10:48 AM
BoRkA's Avatar
Default warped front rotors, cheap upgrade alternatives?
I have a 2001 F4i andafter 5 track dayson itmy front rotors seem to have warped, when braking at speed my front tends to shake.
so since i will be changing them, what are some cheap alternatives? i mean which other brand\model stock rotors will fit with out modification and with out changing the calipers?
I know i can get cheap one's on ebay from a newer F4i, but i figured if im changing them, might as well upgrade alittle if possible.
Old 10-18-2007, 01:53 PM
Jaybird180's Avatar
Default RE: warped front rotors, cheap upgrade alternatives?
Bump for tha cause
Old 10-18-2007, 02:28 PM
Tahoe SC's Avatar
you sure they are warped? offset suspension will also do the same.
Old 10-18-2007, 02:34 PM
BoRkA's Avatar
ORIGINAL: Tahoe SC
Im pretty sure its the rotors, When on the track brakingHARD i get front chatter, it feels like im drilling an impact drill into the ground.
Now when im on the highway i did a test and pressed the brake lever lightly and there was the uneven rotor chatter feel, and the stronger i press the brake the more apperent it is.
If this is not the brake rotors then i have no idea what else it could be. I have a new set of Carbon Lorain SBK3 brake pads on it.
What do you mean by offset suspension? I had my suspension set for my weight about 5 month ago by a reputable shop.
Old 10-18-2007, 02:47 PM
a cheap alternative is difficult to find. i think a direct swap is a more feasible solution.
did you check out the wheel for dents or alignment?
also, some other guy on here had a problem like this and he thought it was the rotors as well. it turned out he had a loose nut in the fornt end. I believe it was the nut in the tree.
Old 10-18-2007, 02:53 PM
BoRkA's Avatar
Alex, whats up man??
I'll look at the steering head nut as well.
did you get those plastics yet?? cant wait to see them.
Old 10-18-2007, 03:01 PM
no, i did not get them yet. they are still detained by the chinese government.
Old 10-18-2007, 03:37 PM
Jaybird180's Avatar
Severe suspension problems can feel like that too. I had ita little. I reduced some compression and took out a touch of rebound. Feels like the tire is skipping, right?
Old 10-18-2007, 03:58 PM
Tahoe SC's Avatar
oh you gots the chatter at hard brake eh? i used to have that when i brake extremely hard...was my suspension.
Old 10-18-2007, 04:17 PM
snowboarding82's Avatar
I have the same problem that I think you're talking about. When I brake hard it makes a loud noise sometimes and my brake lever shakes. Also when I brake really hard like emergency braking, you know what it sounds like when you down shift, the clunking, well my bike does that really really really fast like a machine gun. I think it's trying to down shift and it does it whether I have the clutch in or not. How do I know if it's my suspension?
Quick Reply: warped front rotors, cheap upgrade alternatives?
