URGENT HELP! Side of the road not starting!
Old Jan 29, 2013 | 04:23 PM
Dr.Boost's Avatar
Default URGENT HELP! Side of the road not starting!
Cut to the chase! Washed the bike today (05 f4i) toweled dried it. Everything seemed to be fine... Turned it on and took it for a spin and drove for about 3 minutes. Stopped at the spot I'm at now to take some pics and now the bike won't start
-turns over but won't start
-no headlights working (both low and high I have HIDS)
-no from turn signals working
-tail light and back signals working
-battery seems fine
I'm thinking I fried something when i washed it
Stuck on te side of the road unsure of what to do any help would be great guys!!!
Old Jan 29, 2013 | 04:25 PM
Dr.Boost's Avatar
Also: when I turn the ignition on that normal buzzing start up sound (fuel pump or fan) not sure what it actually is doesn't come on. No initializing sound at all. :/. I have a tool kit with me any advice would be great
Old Jan 29, 2013 | 04:36 PM
74demon's Avatar
Check your connections. One may have got wet. The lights need to work or the bike won't start....
Fuses too.
Old Jan 29, 2013 | 04:49 PM
Dr.Boost's Avatar
If the lights dont work does that mean the fuel pump won't prime? The 6 fuses under the seat look fine... Any idea which connections to specifically check? Are there any other fuses?
Old Jan 29, 2013 | 05:07 PM
74demon's Avatar
No lights=no pump
Check anything that could have got wet up front.
Old Jan 29, 2013 | 05:11 PM
Dr.Boost's Avatar
Damn alright. Looking into it. Thx
Old Jan 29, 2013 | 05:25 PM
Aken's Avatar
July 2008 ROTM
Check the headlight wiring harness plug, too. It would affect both lights and ability to start (bank angle sensor will be disconnected, causing no fuel pump -- it will crank but never fire).
Old Jan 29, 2013 | 07:00 PM
Dr.Boost's Avatar
just got the bike home.. 3.5-4 mile push/walk with it. Shout out to my dad who helped me the entire way and mom who drove behind us with the hazard lights on... about to tear it down and figure this out. will keep you guys updated, thanks for the input
Old Jan 29, 2013 | 07:34 PM
Dr.Boost's Avatar
im having the hardness time unclipping the harness on the left side fairing near the airduct from itself? is there some trick im missing?!
Old Jan 29, 2013 | 07:51 PM
74demon's Avatar
No trick.
