Upper Fairing wouldn't fit after plastic welding.
it's hard to see from the pic id both suports not fitting or is it you can get one and not the other?
how did the cowl get cracked? did it just crack on you by it's self?
If that is the case then I would say yes it is bent and someone force it the cowl on last time and that is Y it cracked so your stay is bent and needs replaced or bent back.
have you tried to loosen the stay and realign it?
I had a similar issue after taking off all my fairings for re-paint. After messing around with it for a while I noticed that there were some wire harnesses in the way. If you just go slow and look around in there with a flash light you might notice some of the wires and connectors causing the front clip to not sit on there the right way. It may take some finess and time but could be benifical.
The reason I'm sure that it's bent is because in its current shape, the windscreen actually blocks the handle bar just a bit. And the left and right "horn" that secures the fairing are not bend at the same angle.
I have tried to bend it back w/ all my might, but it's just too strong. I haven't tried torching it yet, b/c i don't have one.
Ebay has aftermarket one for ~60 shipped, but I am not ready to give up yet.
Anyone else can shed some light on my situation?
thanks
