Undertail & wheel
Old Nov 3, 2012 | 03:00 AM
Ser Jon's Avatar
I join a question.
To me too I want to make to myself such.
Old Nov 5, 2012 | 01:19 PM
Ser Jon's Avatar
Gentlemen, so the wheel will be caught for this undertal or not?
Old Nov 5, 2012 | 01:35 PM
gotcbr's Avatar
Ser Jon,
Not sure exactly what you're asking? Can you be more specific?
Old Nov 6, 2012 | 02:09 AM
Ser Jon's Avatar
The person made undertail:
Here the reference to this subject - https://cbrforum.com/forum/f4i-main-...on-how-109928/
In its undertail there is no deepening over back a wheel. In an original back wing deepening for a wheel is.
As, such uglebleniye over a wheel is in undertail other producers. For example as here:
When driving, the back of a motorcycle falls under weight of the pilot and because of roughnesses on the road. Whether the back wheel will cling for its such undertail without deepening as in an original back wing???
I ask to excuse me for bad English - I from Russia.
Old Nov 6, 2012 | 02:11 PM
gotcbr's Avatar
No worries, just trying to understand what you're asking.
The relief/detent for the tire really isn't an issue. The tire should never touch the undertail whatsoever.
Old Nov 6, 2012 | 02:19 PM
boredandstroked's Avatar
Without the bike sitting on the ground supporting its own weight the rear shock only has 4.7" of travel, as it sits I'd guess it only has about 4" of travel so you'll be fine.
Old Nov 6, 2012 | 04:42 PM
zimdbw74's Avatar
I have a homemade undertail similar to the red one shown above. There is no indent or "deepening" and I have not had a single issue with the rear tire hitting the undertail. I'm 6 foot 1 about 205 lbs or about 2 meters 93 kilos to give you an idea.
Old Nov 7, 2012 | 12:23 AM
Ser Jon's Avatar
And you changed the rear suspension setup that would make it harder?
The tail of the bike was the original or the RR?
Old Nov 8, 2012 | 02:30 PM
zimdbw74's Avatar
My flat undertail was after I had changed my swingarm to the 600rr arm with the 1000rr shock which I think is a little stiffer. However having experienced both the original F4i shock and the 1000rr shock I don't think there is so much of a difference that it would allow the stock F4i to hit or rub a flat undertail
