Twisted Front End Help!
Old Oct 22, 2011 | 05:42 PM
Avi's Avatar
Avi
just like the fork tubes can twist in the lower triple, they can twist sideways on the top one.
support the bike either as suggested from the sliders , or jack it up carefully under the engine (not from the exhaust headers!) with a piece of wood as a contact point, and loosen all pinch bolts and preferably also the wheel axle.
now check with a piece of flat glass over the two tubes. glass is easy to find as a flat plate as opposed to metal.
if the glass touch each tube with 2 points they are parallel, if not straighten them up. now start tightening the bolts a little at a time, while checking alignment every few torquings.
p.s. also loosen the steering column nut in case the two triples are out of alignment with each other.
Old Oct 24, 2011 | 11:42 AM
Sick97SS's Avatar
Originally Posted by mjbanks
Im just getting into learning about the suspension, i know what the preload adjusters are but could you be a little more specific like what to do with them? Thanks in advance!
Here is an excellent suspension guide every rider should read and understand.
Suspension Setup Guide - Sport Rider Magazine
The site also has "suggested suspension settings" for every bike ever made. Every rider is different but they are a good place to start. Here is the F4i page
If you have brand new perfectly strait forks and trips, you CAN NOT install them out of alignment with the bars. Everything will will automatically be "in line" because the upper and lower trips can independently swivel. And there are NO adjustments to be made except for front ride height. So the fact that your bars are that jacked up means that you definitely have some twisted tubes or other damage. You can obviously try to bend them back, but theres always the risk of doing more damage.
I suggest you sell that rear brake stunt setup that you dont use (looks like a nice one) and use the money towards a 954/929 front end. or stock.
Old Oct 24, 2011 | 02:15 PM
mjbanks's Avatar
Registered Users
Thanks sick thats a great guide. So i just tried erns idea and loosened the bottom bolts and tried straightening it up. unfortunately had to do it by myself so it took alot trial and error but i got it pretty straight. I still think its a little off though it just doesnt look right to me. Heres some pics im gonna try avis method next just need to install my frame sliders first.
photo1-1.jpg?t=1319482989
photo2-1.jpg?t=1319482988
photo3.jpg?t=1319482994
its actually a brembo setup with a hel stainless steel brake line. Got new levers (thats the black brake lever) but the original perch is out of commission so need a new one. how much do you guys think i could get for the whole set up?
jmbiro2
F2 Tech
May 19, 2011 06:18 PM
dgk600f4i
Apr 25, 2011 04:28 AM
TwistedCBR
Dec 4, 2007 08:42 PM
Err
Sep 11, 2006 11:08 AM
FLYNBYU
Jan 21, 2006 04:16 AM
