"trunk" not opening
Old 02-11-2009, 11:10 AM
jnmacd's Avatar
Default "trunk" not opening
so i am new to bikes and i don't know the correct term for the storage compartment.. but it won't open.
I look inside underneath the tail light and i think i see the problem, there is nothing connected to the key hole when it turns.. is the black cable supposed to be hooked up to it?
and how do i fix?
Old 02-11-2009, 12:07 PM
whiteflash's Avatar
If your key isn't working you will need to disassemble your tail so you can take the rear seat off. My friend had the same problem (when turning the key the rear seat would not detach). Here are some pictures to help you from the service manual.
Page 2-2:
Once detached you will need to reconnect the metal line to the key hole.
Good Luck!
Old 02-11-2009, 06:30 PM
jonld's Avatar
yep your cable is detached. you gotta disassemble.
Old 02-11-2009, 09:07 PM
krash's Avatar
you dont have to dissasemble. I cant believe you even got a picture of it.
take a metal coat hanger, use the hook and reach up there and pull on the lock mechanism. it happens all the time. once you get the seat off, just reattach it. maybe ziptie it or something so it doenst slip back off
Old 02-11-2009, 09:27 PM
playb0i's Avatar
i used a hook to pull it back in place. i had to play with it for awhile. i was gonna disassemble and crack something, but i got it.
Old 02-11-2009, 10:03 PM
jnmacd's Avatar
I've noticed the plastic screws are stripped... so I will try to grab it with something.. didn't even think of that!
Old 02-11-2009, 11:54 PM
Knocker's Avatar
I had the same problem on my 06. I got some J&B weld and welded the little bastard cable onto the fitting. I have not had any problem since. It seems to me that if you put a fend elim kit on, it puts the cable it a funky position and it slips off all the time.
Old 02-12-2009, 10:14 AM
jnmacd's Avatar
I got it back on... lets hope it stays that way
thanks for the help
mrsmobbins101
04-01-2013 11:07 AM
xp3085
F2 Tech
04-21-2011 07:05 PM
jun167
09-03-2009 06:06 PM
KenG
CBR1000F For Sale / Found
08-09-2009 05:20 AM
Quick Reply: "trunk" not opening
