Trip meter reset
Old Jan 10, 2008 | 07:05 AM
SG_F4i's Avatar
Default Trip meter reset
My battery was really weak that it couldn't crank the second time when it fail to start on the first crank. I pushed the bike and used teh start button at the same time to start the bike. On the same afternoon, I removed the battery to charge it. Everything else was fine after that.
2 days later I went to the gas station to fill up the tank, but to my surprise I could not reset the trip meter which is showing <100 at that point with the button. Can it be that my button is damaged? I just find it too coincidental.
can someone share some experience?
Old Jan 10, 2008 | 08:36 AM
mycvil's Avatar
Default RE: Trip meter reset
Weak battery + failed attempt to start = Reset Trip Meters.
Frustrating for me - I was trying to keep good track of mileage/tanks initially using the trip, and when I installed my new taillight, I ran the batt low. - Hit start - didn't start - jumped it (OK charged it with a nice 2A charger) and started right up - pulled outside and noticed Trip went to 0. - I estimated the mileage based on purchase mileage and the trips so far logged...
Old Jan 10, 2008 | 09:58 AM
ampfp's Avatar
your clock's probably showing wrong time too.
Old Jan 10, 2008 | 11:07 AM
Ruftags's Avatar
Your saying that holding the button does not reset trip odometer correct? If so I haven't run across that and my battery has died a couple times with no problem with using that button afterward.
Old Jan 11, 2008 | 01:57 PM
SG_F4i's Avatar
You are absolutely right. The button is not reacting anymore after that
Old Jan 11, 2008 | 02:45 PM
SchiraF4I's Avatar
My battery died and for 2 months id have to run start it everytime with the trip and time resetting and no problem. You might have a bad cluster, take it to a honda repair center and see if they can trace the problem.
Old Oct 12, 2010 | 08:11 PM
Aaron0866's Avatar
Default Trip meter wont reset
Hi all i have a cbr 929 2000 model i have owned for around 4years now great bike. Just recently the trip meter fails to reset, ive seen other members have had the same issue. I was wondering how to fix this problem, do i need to get the unit looked at by an auto elect? I disconected the battery hoping it would reset. But that didnt really help? Is there any answers to this problem?
"A"
May 13, 2013 05:19 PM
opiecbr
Apr 26, 2012 05:49 PM
jumbo55
Apr 27, 2011 02:47 AM
mdunning
Oct 16, 2010 11:03 PM
Paul Square
Oct 11, 2006 05:49 PM
