transfering maps from power commander
Old Mar 31, 2008 | 08:14 PM
cjr5137's Avatar
Default transfering maps from power commander
i just bought a power commander for my 2006 f4i. i have a yosh rs-3 and stock air filter. My question is my friend also has a f4i 2002 with a powercommander and same set up but full system. his bike was dynoed and has a custom map. is there any way to get the map off his power commander and put it on mine??????????????????????????
thanks
chris
Old Mar 31, 2008 | 09:53 PM
ampfp's Avatar
Default RE: transfering maps from power commander
I dont know if you should, since a full system is different from a slip-on and every bike is unique, but you can.
Use the PC3 software and export the map to a file. Then plug in your PC and import the saved file and download it to the PC3. Easy if both are USB
Old Apr 1, 2008 | 03:50 PM
amnesia's Avatar
You'de think if he paid the big bucks for a dyno'ed custom map they'de at least give him a disk with it for backup! Go figure.
Old Apr 1, 2008 | 09:49 PM
white99gt's Avatar
Bike wil not run the same..What is custom for one bike will not be 100% on another.
Old Apr 1, 2008 | 10:06 PM
Fort Collins's Avatar
I wouldn't even do it. I have a full erion system on my bike and I had it dynoed and then we put it on my friends bike that had just a slip on erion. and his bike ran like ****! rich at times then lean. and it lost hp! and gas mileage.I would just say take your in and get it done yourself it's not worth the problems. but your more then welcome to try. good luck and let me know.
Old Apr 2, 2008 | 01:11 PM
Jaybird180's Avatar
Then custom maps should really be called "one off" or "one of a kind" maps.
Old Apr 2, 2008 | 08:23 PM
rolandk's Avatar
I just installed an RS-3 slip on, K&N air filter, and PCIII on my '05. The standard PC map for thissetupworks really welland I decided to hold off on a custom map.
Old Apr 9, 2008 | 10:11 PM
dreadf4i600's Avatar
How much does the custom map usually run im thinking about putting a PCIII on my 04
Air4Andy
Jul 10, 2013 08:33 PM
Kenyon14
Aug 8, 2011 09:47 PM
Vince954
Apr 21, 2010 08:37 AM
ejvcbr600
May 25, 2007 12:35 AM
Anubis
Nov 8, 2005 02:00 PM
