Tire pressure
Old Oct 14, 2005 | 02:40 PM
gallo74's Avatar
Default Tire pressure
Which is the correct tire pressure for front and rear tires?
Thanks.
Old Oct 14, 2005 | 02:44 PM
Tahoe SC's Avatar
Default RE: Tire pressure
yo mang...depends on your tires and also what you're running them for, such as street, track, canyons, etc.
for the street, you will want higher pressure. i bump that **** up to like 41 front and 37-39 rear for max tire life...but really depends on the tires and ride environment.
Old Oct 14, 2005 | 02:47 PM
1badf4's Avatar
Post which tires you are using.
I think I ran 36 front and back on my michelins
Old Oct 14, 2005 | 03:56 PM
curt954rr's Avatar
If you are talking about an F4i, my 2001 manual says 36 PSI front and 42 PSI rear. I can feel it in the handling on curves if they get more than 4-5 PSI lower than that. It should also be printed on a sticker on your chain guard if it is still there. Hope this helps.
Old Oct 14, 2005 | 04:45 PM
gallo74's Avatar
Thanks Tahoe SC, 1badF4 and curt954rr for your answers, it really helps.
Read ya!!!!
Old Oct 17, 2005 | 12:35 PM
gallo74's Avatar
They are Firestone tires...
ORIGINAL: 1badf4
Old Nov 14, 2005 | 08:02 PM
shraz's Avatar
u have to watch out because the sportier tires have a 42psi max, you don't want them to blow on your face at the air pump :P
I usually go 32 front 34 rear
because they eventually warm up to greater
Old Nov 14, 2005 | 10:30 PM
hondasbest's Avatar
36 FRONT 42 REAR WITH STOCK PILOT SPORTS ON STREET, AND 30 FRONT 30 READ WITH PILOT POWER / SPORTS ON TRACK
Old Nov 15, 2005 | 01:08 AM
Homebrew's Avatar
Tire manufacturers usually spec. cold tire pressures.
Old Nov 15, 2005 | 01:36 AM
marcee77's Avatar
Yo guys-I run 36 in front 42 in rear on my Dunlop 208s any one know if thats a good idea?
scorpionvmu
Feb 19, 2011 12:00 AM
phillycbr
Oct 20, 2009 08:56 PM
Ripper44
Feb 13, 2007 07:49 PM
ameersak
Oct 27, 2006 01:48 PM
canadianF4i
Sep 12, 2006 03:06 AM
