tire pressure
Old Feb 18, 2011 | 09:44 PM
scorpionvmu's Avatar
2011 Ride of the Year
Default tire pressure
i was just wondering what is the tire pressure for the front and the rear for cold weather and for hot weather????
Old Feb 18, 2011 | 10:48 PM
billetproof97's Avatar
What kind of tires?
Old Feb 18, 2011 | 11:07 PM
Originally Posted by billetproof97
What kind of tires?
dunlops
Old Feb 18, 2011 | 11:20 PM
justasquid's Avatar
tire pressures are supppose to be measured at 68 deg's F, or 20 degs C.
For every 10 deg change lower than that, your tires should read 1 psi lower. Every 10 deg's above that, they should read 1 psi higher.
Ideally though, you want to run a little lower tire pressure in really cold weather since it will allow the tires to heat up faster. As for what that will be, its hard to say. A lot will depend on your weight. There is no set point for tire pressure. A person that weighs 150lbs is not going to run the same tire pressure as someone who weighs 250lbs. At least, they shouldn't.
Old Feb 18, 2011 | 11:49 PM
manual says it should be 36 psi in the front and 42 in the rear. this is for bridgestone and michelin tires. but justasquid has a point. i run my tires (michelin's) at the recommended specs on the tire.
Old Feb 18, 2011 | 11:55 PM
F3 manual StephyGees download it. it helps me out a TON wasnt sure if you downloaded it yet.
Old Feb 19, 2011 | 12:00 AM
i have the actual manual in my hand. and i checked the tire pressure that is recommended but was wondering if theres different pressures that people use that might be better to ride with. but i will make sure that its set for recommended pressure.
thank you all for the input.
stay safe.
phillycbr
Oct 20, 2009 08:56 PM
Stay2ned
Aug 6, 2008 08:17 AM
Ripper44
Feb 13, 2007 07:49 PM
ameersak
Oct 27, 2006 01:48 PM
canadianF4i
Sep 12, 2006 03:06 AM
