tip over sensor
Old Jun 6, 2012 | 01:52 PM
dgk600f4i's Avatar
Default tip over sensor
How does it work i wana takr my bike to the strip by my house one of the requirements is it needs a teather hooked up or a tip over sensor i know the f4is have one but i have to show them it works how do i do that? Thanks
Old Jun 6, 2012 | 02:16 PM
squidhead's Avatar
Bike needs to be tipped 60% for sensor to cut out, and kill bike. Its in the left front by the headlight. Another thing you could do is unplug the (BAS) tip over sensor, if you can get to the plug, ( just by BAS)) and un-plug it, then the bike will not start. Oh yeah, then plug it back in, its a piece of cake, good luck.
zimdbw74's Avatar
You could remove the front fairing hold the fairing up right, start the bike and then tip the whole fairing assembly till the bike shuts off. Or start the bike and have someone help you lean the bike on its side till it cuts out. Thats the only thing I can think of to demonstrate that it works.
Or after reading squidheads suggestion you might be able to remove the windscreen which should make getting to the sensor easier without having to remove the whole fairing. The Windscreen is pretty easy to get off with just a few screws.
Old Jun 6, 2012 | 05:18 PM
dgk600f4i's Avatar
Thanks guys il give it a try when i get home
Old Jun 6, 2012 | 06:28 PM
Aken's Avatar
July 2008 ROTM
If you don't want to take anything apart, you should be able to just lean it over with a couple people.
sly280z
Oct 18, 2012 12:34 AM
BETA
Jul 9, 2012 01:05 PM
sco7tys
Mar 27, 2008 06:41 PM
k.600f4i
Mar 21, 2008 06:12 PM
sixshooter989
Sep 27, 2007 06:51 AM
