throttle cable broke?
Old Nov 22, 2006 | 12:03 PM
SkinnyJ's Avatar
Default throttle cable broke?
Hey guys, I have 01 f4i with 23k miles. I am the third owner (ive only put about 6k on it) and can tell you that it has spent some time outside (ie. not garaged kept until now) everything else is fine on the bike rounds solid, just went to a track day about a month ago with it and had a blast.
recently my throttle cable broke, i have a replacement on the way but im just curious is that a "normal" thing? thanks
Old Nov 22, 2006 | 12:12 PM
Jaybird180's Avatar
Default RE: throttle cable broke?
Cables do require maintenance and sometimes replacement.
Old Nov 22, 2006 | 12:33 PM
Tahoe SC's Avatar
yup...you're supposed to remove it and lube it ever so often...one of the biggest pita's in the world!
my stocker lasted like 35K and was still good but i replaced it anyway...
Old Nov 23, 2006 | 08:25 AM
SkinnyJ's Avatar
kk so i shouldnt be worried? and just use wd40 for lubing of the chain?
Old Nov 27, 2006 | 11:02 AM
Jaybird180's Avatar
There is a cable lube and tool made for it. Your dealer should do it at service intervals if you don't do it yourself.
Old Nov 27, 2006 | 12:47 PM
Tahoe SC's Avatar
no...chain lube for your drive chain...
cable lube stuff for your cable...i use lithium grease...and spray it, but it's thick and will take like a million years to make it's way down the cable...
NYKnick1015
Mar 18, 2011 08:00 PM
BronzeAccord
Sep 29, 2008 02:40 PM
punkfish
Jul 15, 2008 11:27 AM
AlphaBiker24
May 23, 2008 07:03 PM
bladerunner69
Jun 17, 2006 01:25 PM
