Throtle grip loose.
Old Aug 25, 2008 | 01:10 PM
stryker759a's Avatar
Default Throtle grip loose.
I might just be crazy but i have a little play in my throttle. I can move it a little with out it engaging is this normal. Thanks
Old Aug 25, 2008 | 01:19 PM
bakesf4i's Avatar
Default RE: Throtle grip loose.
Yeah you should have some freeplay within your throttle cable, as long as its not hella much. You can always tighten it up to your liking
Old Aug 25, 2008 | 01:29 PM
How do i tighten it up i turned the screws that bold into the handle bar but that didnt fix it?
Old Aug 25, 2008 | 02:54 PM
usetheffours's Avatar
You should have 1/16" to 3/16" freeplay. You need to adjust the nuts on the top tube your throtle cable runs through. One looks normal and the other is long. Loosen these two nuts and movethe long onearound till it is were you want it then tighten the little nut down to lock it.
Old Aug 25, 2008 | 07:45 PM
RojerLockless's Avatar
turn the big screw like he said it will tighten up
jtjr008
Mar 15, 2010 05:59 PM
scastillo13
Aug 11, 2009 03:47 AM
Enders ride
May 13, 2006 11:28 PM
KISSFAN
Jul 23, 2005 02:45 AM
barkbarkmeyah
Jul 21, 2005 09:18 AM
