Is there a difference cbr f4 forks and f4i forks
Old Sep 3, 2013 | 08:19 PM
wixxxman's Avatar
Default Is there a difference cbr f4 forks and f4i forks
Hi there I have a line on some forks just curious if the cbr f4 forks are the same as the f4i forks ?
Thx for the comments
Old Sep 3, 2013 | 11:30 PM
"A"'s Avatar
"A"
Pretty sure F4 fork legs are 41mm diameter, F4i for legs are 43mm diameter.
Old Sep 4, 2013 | 12:05 PM
DonnyBrago's Avatar
No.
Old Sep 4, 2013 | 01:15 PM
wixxxman's Avatar
Need some help here has any one done this swap? I think the only difference is where the front fender bolts
Old Sep 4, 2013 | 03:47 PM
boredandstroked's Avatar
Exellent job reading the previous posts telling you the only difference is not where the fender bolts on. And why would anyone put older, worse parts on a bike?
Old Sep 4, 2013 | 08:36 PM
wixxxman's Avatar
Oh man!!!! Can get that time BACK!!!!! (Reading the last reply) ,Oh well,good try on the reply and thanks for the effort.Just a heads up a lot of the parts are compatible with the f4i!!! And to go as far as a "worse part" just some advice wouldn't go around posting that on here..
Just thought I would throw it out there one last time has any one done a f4i fork swap with f4 forks?
Just in case if anyone is curious this bike I'm trying to keep in a budget I'm getting a set for next to nothing on a trade,besides there "like new"
Old Sep 4, 2013 | 09:36 PM
RudyGT's Avatar
i havent done the swap but the pipe's should work even though the OEM numbers are off, you absolutely need to do the swap because they are bent right?
i polished mine and resprung them, working as intended, no need to throw money away.
Guambomber
Sep 24, 2008 09:32 PM
jfunkRR
Apr 30, 2008 09:23 AM
japanese900rr
Aug 15, 2006 11:52 PM
abreu3r
Apr 24, 2006 05:55 PM
