Is there a difference cbr f4 forks and f4i forks
Hi there I have a line on some forks just curious if the cbr f4 forks are the same as the f4i forks ?
Thx for the comments |
Pretty sure F4 fork legs are 41mm diameter, F4i for legs are 43mm diameter.
Originally Posted by wixxxman
(Post 1248914)
Need some help here has any one done this swap? I think the only difference is where the front fender bolts
(Post 1249065)
Oh man!!!! Can get that time BACK!!!!! (Reading the last reply) ,Oh well,good try on the reply and thanks for the effort.Just a heads up a lot of the parts are compatible with the f4i!!! And to go as far as a "worse part" just some advice wouldn't go around posting that on here..
Just thought I would throw it out there one last time has any one done a f4i fork swap with f4 forks? Just in case if anyone is curious this bike I'm trying to keep in a budget I'm getting a set for next to nothing on a trade,besides there "like new" |
i havent done the swap but the pipe's should work even though the OEM numbers are off, you absolutely need to do the swap because they are bent right?
i polished mine and resprung them, working as intended, no need to throw money away. |
