temp gauge
well the fan should kick on at like 220 I think, Normally if I set anywhere for a while I just shut the bike off
Just make sure you have sufficient coolant and Oil is good.
Ive had it up to like 236 I think , I cant quite remember though.
Daniel Thompson
Daniel Thompson
yea mang...high way flying is like 180 and when you start hitting traffic and stop and go will go to like 222...and stopped at traffic will go higher but fan should kick on by 225-228. i think the fan switch is actually set for like 220, but there is a lag from what the fan trigger sensor reads, which is in the radiator, vs. what the temp guage says, which is near the core.
also, if you have lots of gunk and old coolant and build up in the lines, then the bike will run hotter or get hot quicker. frequent flushing will help prevent this.
t
t
cBrentb
Dec 24, 2011 07:53 PM
