tailight mounting?
Old Sep 22, 2006 | 06:59 PM
JVracer04's Avatar
Default tailight mounting?
so i have a fender eliminator with the led tailights and i wanna go back to the stock style tail light with intergrated led blinkers
BUT... how does the factory tail light mount? does it mount to the subframe?
cuz my rear fender has been cut to fit the fender eliminator and the previous owner did all this work to the bike
Old Sep 22, 2006 | 07:17 PM
Blackdog F4i's Avatar
Default RE: tailight mounting?
Yes, it mounts to two tabs on the undertray.
If you want to go back to the stock "style" taillight you will need another undertray or you will need to makeup some tabs to mount it. Shouldn't be a big deal.
Old Sep 23, 2006 | 03:07 AM
F4Isvt's Avatar
It mounts to the rear plastics by two phillips screws. Not the undertray. I have made my own undertail and cut the whole tray out and my taillight is still there.
Old Sep 23, 2006 | 10:04 AM
traitorhound's Avatar
ORIGINAL: F4Isvt
depends. . on the 01-03 it mounts to the undertail. on the newer one they are on the rear plastics. . i know cuase i have both
Old Sep 23, 2006 | 10:48 AM
JVracer04's Sig says '03 F4i. On the 01-03 the taillight fastened to two plastic tabs on the undertray by two metal studs on the back of the stock taillight and is held in place by two nuts. It also uses two rubber grommets to isolate the taillight from vibration.
new06f4iowner
Jun 27, 2010 02:48 PM
new06f4iowner
F4i - Wanted
Jun 5, 2010 09:14 PM
Ziggyman
Jun 29, 2009 07:41 PM
mowdiddy
Mar 17, 2008 11:58 AM
dizzie56
Nov 24, 2006 10:22 AM
