Integrated tailight
Old Nov 17, 2006 | 03:06 PM
dizzie56's Avatar
Default Integrated tailight
Anybody have a problem wit their integrated tailight lightin up when the break is applied? Tryin to put mine on and when i test it out it doesnt get any brighter. Actually seems like it is on the whole time as bright as it is.
Old Nov 18, 2006 | 02:31 AM
XLR8's Avatar
Default RE: Integrated tailight
I just installed mine last week and it works great. Before I started I took a look at the below web-site to make sure I understood the wire hook ups. The instructions that came with my Clear alteritive Tail weren't very clear.
I did install with the resistors to slow down the blink rate. It slowed them down a bit, but once I installed LED flush mounts on the front they sped up again. I'm going radio shaq and try to install them on the fronts as well. Maybe that will slow them down.
Guess I didn't really answer your question, but maybe this web-site will help ya..... Good luck
http://hooliganbiketech.dynup.net/ho...frameindex.htm
06 1Krr (Silver)
Clear Alteritive Tail
LED Flush Mounts
CW Elminater
Old Nov 18, 2006 | 07:19 AM
Blue Fox's Avatar
Retired Moderator
ORIGINAL: XLR8
Just replace the stock thermal flasher with a Variable-Load Electronic Flasher. They don't cost much and you don't have to wire in resistors. The stock thermal flasher IS the reason why the LED's blink extremely fast. Replace the flasher and problem solved permanently.
Old Nov 18, 2006 | 10:45 AM
dizzie56's Avatar
thats funny cause i got the clear alternatives light and it dont work. o well, gonna have to give them a call or somethin
Old Nov 18, 2006 | 11:57 AM
XLR8's Avatar
When I got my LED Turn signals they gave me a new Flasher unit, but I'm not sure where it goes, or how to change it out. The unit was a universal so I'm sue it don't match up.
I'll check into it....
thx
Old Nov 23, 2006 | 04:18 AM
Kendrick07's Avatar
I'm pretty sure you have the wiring wrong. My guess is that you switched the wire that is for your brake light with the one that is consistently on when not braking. As a result, your brake light is always on and the regular driving light turns on when you brake. I know somebody who did this exact thing, but it wasn't with a honda so this is just a guess.
Old Nov 24, 2006 | 10:22 AM
dizzie56's Avatar
It comes wit a stock wiring harness so u dont have to connect any wires to each other. Its just plug and play.
bluedevil3758
Aug 16, 2010 07:31 PM
Jmclmorrow
Jun 11, 2009 06:40 AM
jardine
Sep 20, 2008 02:37 AM
mowdiddy
Mar 17, 2008 11:58 AM
cleansho93
Sep 28, 2007 03:48 PM
