integrated tailight electrical question
Old Aug 16, 2010 | 12:51 PM
bluedevil3758's Avatar
Default integrated tailight electrical question
hey guys got an integrated tail light and hooked everything up and am blowing the 10A fuse for the instruments and running lights, the blinkers and brake lights work on it, i only used the wires from one of the bulbs to the oem tail light should i have used both sets of wires? thanks
Old Aug 16, 2010 | 02:06 PM
ok well i connected the wires for the other light bulb in the oem tail light and im still blowing the fuse, i think it has something to do with the ground, the integrated only has one ground coming out of it, and i connected all the grounds to that wire, both blinkers and the grounds from both of the oem bulbs, should i set it up differently? maybe blinkers to one ground and integrated to the other ground?
Old Aug 16, 2010 | 06:20 PM
redzintimidator's Avatar
Did you connect a green/yellow to ground? Thats a nono....
One ground wire to the taillight will be enough.
this might be of help as well:
Old Aug 16, 2010 | 07:31 PM
hey thanks def helped got everything sorted out
Jmclmorrow
Jun 11, 2009 06:40 AM
jardine
Sep 20, 2008 02:37 AM
mowdiddy
Mar 17, 2008 11:58 AM
cleansho93
Sep 28, 2007 03:48 PM
dizzie56
Nov 24, 2006 10:22 AM
