subframe question
Old Apr 3, 2011 | 06:57 PM
oldskool21's Avatar
Default subframe question
i have seen it done on a 900rr but can i got from the nanna seat to the slit seat with keepin my subframe,i kno to do it right i will have to but i was wondering if ne one has ever tried putting the split seat on a nanna subframe if so how much modding is ther to do
I DONT NEED THE REAR SEAT I AM JUST WORRIED ABOUT THE FRONT SEAT
Old Apr 3, 2011 | 09:55 PM
gotcbr's Avatar
Modding the banana seat subframe is more trouble than its worth if you're wanting to do a real split-seat swap. Not that it can't be done, b/c it has, but its really more trouble than its worth. There's just no need to re-invent the wheel, so to speak, when the F4i split-seat subframe is a direct swap & bolts right up. It just saves so much time & energy. <---Work smarter, not harder approach.
If you're really intent on modding a banana seat subframe to make it look like a split-seat, what I've seen guys at the track do - is to cut off the rear latch bracket of the banana seat subframe & attach a race tail cowl. You'll need to use a seat pad on top of the plastic for your front seat.
Good luck on your choice.
Old Apr 3, 2011 | 10:22 PM
oldskool21's Avatar
naw ive figured it out with about 7 hours of research im gonna find the f4i split seat tail nd only run the front seat i dont need a passenger seat ne ways,but if ne one has ne other input let me kno
thef4i
Jun 5, 2009 02:30 AM
mxman87
Mar 22, 2009 10:07 AM
JDubF4i520
Jun 10, 2007 05:35 PM
TennesseeCBRF2
Apr 29, 2007 06:47 PM
05f4i16
Aug 25, 2005 04:38 PM
