Speedo Problems
Old Jul 3, 2008 | 11:34 AM
Gutter's Avatar
Default Speedo Problems
Hey everybody. I am having a problem with the speedometer/odometer on an '01 F4i. Basically, they only rarely work; that is, the LCD displays on the dash function fine, but the speedo reads zero and the odo doesn't count kilometres. I am 99% sure that the problem is in the vehicle speed sensor (VSS) based on the fact the when the speedo doesn't function I get an FI warning light that seems to be related to the FI system recieving an error from the VSS. Now, I checked up in my service manual to check how to test the VSS to confirm that it is the problem and it looks like a huge pain in the butt! According to the manual, I have to pull the tank (and everything else involved in doing so) and the whole throttle body assembly to get at the stupid thing.
So, I guess my question is does anyone know any tricks on how to get to the VSS so that I can avoid having to pull the top half of my bike off? If not how big of an undertaking is pulling all these parts?
On a related note, the rare times when the speedo functions properly are always on hot days when the motor has had a chance to heat up beyond 100 degrees (e.g. in heavy traffic). How could heat affect whether the VSS works or not?
Thanks for any help.
Old Jul 3, 2008 | 04:02 PM
Daemian's Avatar
Default RE: Speedo Problems
i am having the same problem. From what i could fine on the net you can trying cleaning the connections to the ECU as that can sometimes do it. You are right it is a huge pain in the ... to get to the sensor. W/ mine, we tested it and the sensor seems fine so i suspect a loose connections somewhere (it suggests that in the manul before a bad VSS) but i have been unable to remedy the problem as of yet. see this Link for more info
if you find any tricks please let me know! this is really annoying!
500tie
Mar 8, 2013 08:32 AM
rumble_mommy
Jun 16, 2011 05:17 AM
Monty08
Feb 21, 2011 07:33 AM
nikolas812
Oct 4, 2009 11:04 PM
SIRR1
Mar 5, 2009 07:29 PM
