Silvery Metallic Dust In Used Oil
I hope it's nothing ben, but this advice for diagnosis from 74demon is pretty simple if you wanna get an idea as to what it is before next season. The oil pressure test isn't that hard from what I've read in the manual. I think you would've noticed a knocking under light acceleration by now, so you can probably rule out the rod bearings.
The cct will make noise, but not put the silvery stuff in the oil. Clutch is probably gone as well. Take a good look at that. But you will probably find you have bad bearings. If your rattle is a knock, usually while lightly accelerating, the rod bearings are bad and you are killing the crank. Bad main bearings will show up in an oil pressure test.
