shooting 9" flames under decelleration
RE: shooting 9
i think you should upload a video of it shooting flames, as that would be the only real way to tell
let us know how the new map works, and which one you used!
________
Lovely Wendie
________
Lovely Wendie
RE: shooting 9" flames under decelleration
Check the ground wire on your PCIII as well. If its loose your PCIII could be kicking back and forth to the "zero" map and making the bike act rich. You usually get a glimmer of an FI light if thats happening, but not always.
If you have the software and cables (and apparently you do) save a copy of the map you have, then lower the fuel values on the 0 and 5% throttle table of your map, save that as a different name load it in. If you back firing when you close the throttle that will help.
