she still seeps oil
Yup a cheap fix! but only thing is i want the JB weld STIK. Its in a putty form which i can use to knead and than apply and push it down into the metal. I just hope auto zone carries it.
"J-B STIK
Quick, easy and clean. J-B STIK Weld is a hand kneadable, steel-reinforced epoxy putty adhesive/sealant that will plug holes and make permanent repairs on wet and dry surfaces. It will even cure completely submerged in water or GASOLINE! Simply knead thoroughly, with your fingers, a portion necessary for the repair and apply. J-B Stik will fully cure 20-30 minutes; and can be drilled, sanded, filed, tapped, machined, and painted. J-B Stik requires no tools or "prep time", and makes no mess."
It sounds amazing
"J-B STIK
It sounds amazing
