she still seeps oil
Well no luck with the repair, i discovered that the engine casing was broke and that's why the bolt didnt catch and tighten. About half of the casing is broken off leaving half of the bolt exposed. I tried fixing this by throwing a longer bolt through than using a nut to tighten it on the other side. Still no luck it still leaks out of the broken casing. I dont know what to do, even though its only a wee bit of seepage which accumlates about a drop of oil in one and a half week it still bothers me cause i cant do anything about it! im thinking about just putting black RTV sealent into the area of the broken casing, and around the outside of the bolt maybe that'll help if not im probably going to sell the bike i have a 2005 kawasaki 636 waiting in my garage to be used. The only problem is i dont know how much money i can get for the cbr i spent about 3500 dollars on it. And looking to get atleast 2900! i dont wanna tell them about the broken casing, but than i dont wanna be a jerk. i wanna fix that damn thing! how about paint? or if i solder a new casing on lol!
Originally Posted by Gotpepsi
(Post 933395)
haha no freakin way. that kawi is awesome!
It was worth a shot.
I bet the RTV would work. That stuff is indestructible. I used to work in the aerospace industry and we would use RTV all the time. If its good enough for Jet engines im sure it would be ok on your honda motorcycle. |
Fixing a problem is not as much fun as blowing it up.
Originally Posted by KdubyaH
(Post 933405)
seal blew hmm. Sure you don't have back pressure issues causing the crank case to get high pressure blowing seals up? Or is this the only seal that's bad?
The only area where oil seep is where its pointed to with the black line.
http://i44.photobucket.com/albums/f1...m/Untitled.jpg Right now its not acually dripping oil, but i can see the bolt get oily after about 3 rides in front of the bolt and behind it. And if i put a paper towel into the area right under the bolt the paper towel gets wet with oil. |
have you try jb weld,
Good Freakin idea!!!!!! im going to try that tomorrow!! do you know where i can get the hand kneadable type? so i can push it into the crack!
