Running temp for F4i?
Old Aug 12, 2013 | 01:21 PM
AirmanSkee's Avatar
Default Running temp for F4i?
The previous owner told me that te fan may need replaced or sensor for it to kick on but I was wanting to know what temp the fan normally kicks in so I can watch the temp to see?
Also, how hard would it be to replace the sensor or fan if need be?
Old Aug 12, 2013 | 01:25 PM
boredandstroked's Avatar
If it starts by 220 your fine.
Old Aug 12, 2013 | 03:29 PM
AirmanSkee's Avatar
And if it doesn't, what would be the easiest way to diagnose if its the fan or sensor? Noob questions here.
Old Aug 12, 2013 | 03:55 PM
bigboi18184's Avatar
My fan kicks on around 225 and shuts off around 223
Old Aug 12, 2013 | 04:29 PM
5t341th's Avatar
ground the fan plug and see if the fan turns on or not
Old Aug 12, 2013 | 05:13 PM
Aken's Avatar
July 2008 ROTM
My fan kicks on around 228-229. It will vary by bike, yours may be any of the temps mentioned in this thread. If you don't see a fan kicking on by 230, though, you can officially assume something is wrong.
Old Aug 12, 2013 | 10:48 PM
Kopi Ko's Avatar
Mine on 107 Celcius, that's 224 F kicks fan
Old Aug 13, 2013 | 12:40 AM
AirmanSkee's Avatar
I rode all evening and I couldn't get it to go above 181*. Hmmmmmm....
Old Aug 13, 2013 | 07:36 AM
Kopi Ko's Avatar
You could try shorting your fan to see if it's spinning or not
If you think thermo unit is broken, it's here:
37760-MT2-003 SWITCH ASSY., THERMO $39.48
Old Aug 13, 2013 | 10:08 AM
Temp shouldn't go much higher than 180 while riding, mine runs 175-190 while riding depending on my speed and outside temp. Only time I get temp to 225+ is if i've been riding awhile and stop at a redlight for a minute or two.
Or after warming bike to temp from riding, I go through town where speed is 25, and
Temp still doesn't get much higher than 210 unless I get caught at a light.
