Running Rich
Old Jan 10, 2010 | 12:04 PM
scooterc14's Avatar
Default Running Rich
Hey guys Im fairly new to riding only been riding for 4 months or so. I've installed a Two brothers slip-on exhaust and noticed the bike was running rich. Well just the other day I installed a k&n filter and new plugs. Havent hada chance to really run it since its been cold. Will that help counter act the problem or do i need to go deeper?
Old Jan 10, 2010 | 02:13 PM
teko1020's Avatar
Time to invest another 250-300 in a PCIII.
Old Jan 10, 2010 | 05:23 PM
Junior2552's Avatar
all of our bikes run rich. is it stalling out, smoking, or anything like that? or does it just smell rich?
Old Jan 10, 2010 | 05:34 PM
xjoewhitex's Avatar
With a pipe and air filter you should have leaned the bike up since you haven't adjusted your fuel.
Old Jan 10, 2010 | 08:46 PM
scooterc14's Avatar
It smells like it sometimes but the inside of my pipe tip is really black. Im gonna ride it tomm so we'll see how it goes. is it gonna hurt it to run it lean?
Old Jan 10, 2010 | 09:07 PM
dans03f4i's Avatar
Your bikes internal fueling map stored in the "black box" CPU unit is set to run the standard fueling map, which is more geared for a stock air filter and the stock pipe. With a K&N filter and an aftermarket pipe, you've got more air while the "black box" is still putting out the same amount of fuel. Get a Power Commander III to load a different fueling map. Your bike will thank you.
Old Jan 10, 2010 | 09:16 PM
scooterc14's Avatar
Thats gonna be the next thing I do but gotta wait for taxes to do that. Now if I do a PCIII and get a new bike can i buy a map for that or do i need to get a diff PCIII?
Old Jan 10, 2010 | 09:30 PM
teko1020's Avatar
Unless you get another F4i you will need a different PCIII... different connectors.
Old Jan 11, 2010 | 10:39 AM
Junior2552's Avatar
the inside of a lot of exhaust pipes turn black. i have a scorpion slip on, and they claim there was..."no remapping needed", as much as i don't believe that, i didn't get a pcIII. and you said before, that it was running rich. running rich isn't bad as running lean. which one is it sir?
Old Jan 12, 2010 | 02:48 AM
scooterc14's Avatar
Hey guys excuse me for being new at this and still learning but how can I tell if the bikes running lean now? I only get the raw gas smell on startup now.
