Is rotating around the tank a bad habit? (street cornering)
RE: Is rotating around the tank a bad habit? (street cornering)
ORIGINAL: PlayfulGod
the correct way is to move side to side using your legs. Your feet should be on the ***** of your feet on the pegs, toes slightly pointed outward, this will make your knee stick out (w/o leathers n pucks tho be careful, ie slow down), act like you're trying to kiss the mirror with your head, your armpit should be over the gas filler.
I'm by no means perfect, and I don't claim to be the Rossi of the roads, buthere's a pic of my friend exhibiting a nice entry line and riding form:
ORIGINAL: Jaybird180
Hanging off on the street is not only illegal but will also get you laughed at.
hangin off thru town may get you laugh at. I aint seen no one laugh at anyone doing in the twisties.
the way i see it is that rotating around the tank isn't bad form. it's taught by certain riding schools--but as you're describing it, you're doing it wrong! (jk)
pivoting around tank is helpful for smooth transitions, but you still have to "hang off". if not, there's a good chance you're getting "crossed up" which is what happens when your butt sticks out, but your upper body is still over the center line of the bike.
there are 1million ways to skin this cat. even some very fast riders don't hang off as much (doohan or eddie lawson, for instance), and others hang off a LOT (john hopkins)--once you get the basics down you'll see that there's a million different ways to do it, and if it works for you, it's fine.
here's me:
notice my head position and upper body position. and compare it to...
john hopkins:
his chest is completely against the tank and elbows and upper body WAY out over the side.
nicky hayden:
nicky is a little more upright, a little less upper body displacement than hopper.
mick doohan:
wayne rainey:
so, as you can see, riding form varies from rider to rider. every single body part position has its pros and cons, but most importantly you have to develop form that works for you.
here's me:
john hopkins:
nicky hayden:
mick doohan:
wayne rainey:
ORIGINAL: charlos
here's me:
here's me:
btw, Your clutch lever seems far apart from the clipon. (Do you have long fingers?)
So, I'll keep rotating when I ride on backroads (just little bit to be unnoticed)
and hang off when I go to Gap or track.
ORIGINAL: StockSH
Thanks a lot!!!, Charlos.
