Front tire turning/rotating wrong way..
I just noticed on my 06 F4i, that I picked up about a month ago, that the front tire arrow is pointing the wrong way... I guess it was mounted/installed backwards?
What's the easiest way to fix this? Does the tire need to be remounted or can I just take the wheel off and flip it?
Also, the front tire is a dunlop while the back is a Bridgestone Battleaxe, should I just replace the front to match the back? Or does that really matter?
Both have a lot of tread left.
Thanks!
Thanks!
Most if not all bike tires are unidirectional. If the tire is currently mounted correctly it may be mounted incorrectly if you simply flip the wheel to be facing the right direction.
For what my opinion is worth I would have the tire taken off and re-mounted this way the tire, wheel, and rotors will all be correct. Should cost $20-$40 if you just take them the wheel.
This. Take it off, have the tire mounted properly if it has enough life left that you want to keep it. Verify the brakes are all in the right direction while you're at it, then you're good to go.
If there is a directional arrow, it matters. Besides the rain-handling mentioned above,
the belts that are the core of the tire have a bias. When running they need to flex and
deal with the lateral, torsional and side wall forces operating on the tire. It's kind of like petting
a dog the wrong way...one way the hair lays down, the other makes it stand up.
Crude analogy but gets the point across, I hope.
I wasn't aware that rotors had a particular bias, so I'll defer to the others on that aspect.
Good to know, though, always learning something here. ;-)
Ern
Ern
