Replace dogbone on F4i?
Old Jan 18, 2011 | 08:09 AM
Lando's Avatar
Default Replace dogbone on F4i?
Is there a good DIY or "best practices" to replacing the dogbone on the rear shock? I have a lowering link that I would like removed and converted back to stock.
Old Jan 18, 2011 | 10:22 AM
Ry.Hibiki's Avatar
Thats a good question because i want to lower my other bike.
Old Jan 18, 2011 | 03:17 PM
bluedevil3758's Avatar
i replaced mine back to stock,
1. put bike on stand
2. jack up bike under exhaust pipe until load is off the rear suspension an you can loosen and remove the dogbone bolts.
3. Install new link, adjust jack as necessary to install new one.
its that easy
Old Jan 19, 2011 | 07:15 AM
Lando's Avatar
its that easy
So you put your bike on a rear swing arm stand then jacked it up by the exhaust manifold? Isn't the bike weight an issue on the header?
Old Jan 19, 2011 | 03:28 PM
no theres a bolt right on the bottom i put the jack under, didnt even lift bike just took off some of the weight, ive done it twice, the second time to add height to the rear shock
Old Jan 20, 2011 | 12:55 PM
HondaDustin's Avatar
Lando a motorcycle jack in specific, not sure if you got that or not. They sell them at sears for 90 bucks.
Old Jan 21, 2011 | 07:07 AM
Lando's Avatar
I'm not sure thats the jack bluedevil used. I thought motorcycle jacks are not recommended for sport bikes, only really useful for ATV, Harley's and bikes with frames that run under the engine.
I would think a standard jack would be fine for jacking a small contact point of the motor, considering the rear swingwarm is in a stand.
Old Jan 21, 2011 | 02:25 PM
LizzardKing's Avatar
Registered Users
There's also a front fork lift from norther tool for that will set you back 40 bucks
Good for 650 lbs
Old Jan 21, 2011 | 04:58 PM
HydroPrelude85's Avatar
i have a lowering link "bone" for my 03 f4i if you would be interested in trading for a stock bone
Old Jan 22, 2011 | 09:34 PM
luckboxx74's Avatar
I've got a stock bone from an '01 I'd sell for $15.
