Rearsets vs Riser plates
I assume you mean adjustable rearsets? The risers will probably be a bigger change, but the direction and position are fixed. With the rearsets you can move things around to get it where you want it. As far as the rear brake goes, that connects right onto the rearset and won't need to be changed either way.
Have you removed the feelers from the footpegs yet?
If you're dragging PEGS (not toes) without the feelers on the street, you need to work on your body position big time.
I can easily get a knee down trackside without coming close to the footpegs and I am not reaching my knee out by any means.
If your toes are dragging you need to work on body position.
If you have awesome body position and you have been riding for years or have significant track experience combined with a good tire/suspension setup and are having problems dragging footpegs on the street, then you wouldn't be posting this question.
Another possibility is that your bike is lowered or the suspension is setup really bad which would make it easier to touch down.
That being said you would have to be pretty damn quick to have any issues with the 1" up and back rearset plates even on the track.
The right side (brake) by the way does not require any other modification to work with the plates.
When cornering with a street bike, it is best to try to keep the bike as upright as possible. More bike lean is not better, you should lean with your body as much as possible to compensate. I used to get my feet taken off the peg every now and then til I learnt how to corner properly. Now my feet don't even come close to the road!
With dirt bikes it is the opposite, or if you are doing those weird Japanese courses that Yum likes to post videos of.
