Rear dog bone install
Anyone know how to install a rear dogbone for the suspension? Let me know whats needed and what i need to remove, if i can just take my lowered link off and replace it with oem that would be great, if i have to remove the rear wheel and rear shock let me know.
I have done it on my brother-in-laws ninja. They look similar. He had it lowered and then didn't like it. I put it up on stands then used a floor jack to manipulte under shock assembly to get bolts out. I didn't have to remove rear tire. I was just real careful with the jack so not to make the bike unstable. If I remember right I have heard of guys doing it on just the side stand, but I couldn't get floor jack under the bike(too low). Be careful and have a buddy help ya incase it wants to tip.
The dog bone is not hard to do. I had some ratchet straps and a swing set because we didnt have a garage with rafters. Just hang the rear of the bike up and put a block under the tire so it doesnt drop really far when you disconnect the suspension. To get the dog bone out you have to loosen up 2 otherbolts along with taking out both the top and bottom bolts that hold it on. Otherwise you will be able to wiggle it but it will never drop out. Remember you only have to loosen the other bolts. You dont have to take them out.
I would just like to add that you will probably not like riding the bike anymore because it will dip into corners abruptly instead of smoothly like it would with stock height. I took mine back off because of it.
Oh maybe i didn't make this clear but im raising it back up haha. Its lowered and well a bike at stock height handles best so i ordered a used one from MDGracing (great guy btw) and will be installing it today. Is there anything i should do differently now?
