rear brakes
Old Sep 18, 2005 | 07:05 PM
blinkster240's Avatar
Default rear brakes
looks like its time to replace the rear brakes on the bike. can the pads be changed without bleeding them??
Old Sep 19, 2005 | 01:40 AM
kiggy74's Avatar
Default RE: rear brakes
Haven't need to do pads yet, but I think that calipers come off and there are just little clips holding the pads in.
Old Sep 19, 2005 | 04:14 AM
xmunxjai648's Avatar
yeah they can be change w/o bleeding...almost the same procedure i do to car brakes....u'll need a small C clamp to press in the caliper
Old Sep 19, 2005 | 09:55 PM
thanks for the reply!!!!
Old Sep 26, 2005 | 09:19 PM
easy as pie!!
Old Sep 27, 2005 | 06:12 AM
yeah and u can use the same technique when u do the front brakes...cars or bikes..but u'll need a bigger C-clamp for the car
Old Sep 27, 2005 | 06:50 PM
yup... it was really easy. the front brakes will be a while so we will see then!
Old Sep 28, 2005 | 12:42 AM
fullmetalf4i's Avatar
only time you realy need to bleed in pad maitnance is when you get the calipers stuck together (good use for the c-clamps) only reason i bled the brakeson my XR was beacuse i also put on some steel braided lines. bleeding isnt really a big deal, takes maybe and hour if you do it right the first time.
Turbulenz
Dec 29, 2011 12:39 PM
nickleback7004
Oct 26, 2011 07:14 AM
spdbump36
May 8, 2008 09:11 PM
jfunkRR
Feb 16, 2008 09:15 PM
tdk5946
Feb 21, 2007 06:46 PM
