rear brake squeak
rear brake squeak
My rear brakes are starting to squeak a bit. I did a search, and looks like you guys mostly recommend sanding the pads down a bit. Is there an easier way to access the brakes without having to move my slip-on? It's a pretty tight squeeze in there.
Should I also sand down the rotors a bit? Or is that overkill? I was thinking of just wiping it down with a wet rag or something to remove residual dust.
RE: rear brake squeak
ORIGINAL: Stephens
If you ignore it, its gonna get worse. That squeak you hear is the wear down indicator. Telling you to replace your brake pads. How much is your life worth when your going down the road and you can't stop in time?
The wear indicator seems okay, as I took a look at it last weekend. I don't remember the exact depth between the pad and the indicator, but it definitely still has some life left. Unfortunately, I prob didn't sand the pads down enough, as after a few mins of riding, the squeak started coming back.
Hayden06F4i
06-17-2008 09:50 AM
