Quick Oil Change Question
I just changed the oil on my f4i and it wasnt too bad the oil filter was a bitch to get off but I used a K&N with the nut on the end so I wont have to fight with it next time. My question is I put 3.5 quarts of Mobile 1 4 stroke in there and when I stand my bike straight up the oil is at the VERY top on the little window on the side. Like if i move the bike side to side you can see the oil line. She seems to run WAY better and alittle cooler(It was way over due, the ****s at the dealer said they just change it right before I bought her... That was some of the blackest oil ive seen and ive been doing oil changes for years) Is that too much oil? Should I drain alittle? I know its suppose to be between the two lines but will it hurt it
Also is it normal when you turn the key that the oil light flashes? It goes off as soon as I start it. I can't remember.
Thanks everybody!
Thanks everybody!
its not gonna hurt any gaskets if its at the max line....thats y there's a max line....ive heard of stunters filling a liter over the max line, but when u have both wheels on the ground, isnt that gonna aerate (idk how to spell it) the oil pan and/or blow a seal?
did you remove the fairing for to change the oil filter? I am reading some of the threads on oil changes, it seems most people don't have issue to remove the filter with the fairing on. wondering if it's still necessary to remove the fairing..
^ +1
its should be fine,i'd rather have a C-hair over than under anyday
Thanks everybody for the replys I just wanted to make sure it was ok. Im prolly guna change it again in the next 4-5weeks before winter storage.
viva_brasil
Jun 9, 2008 04:38 AM
